Topic: Spring ID (Read 1318 times) previous topic - next topic
Spring ID
I noticed a little green tag on my TC rear springs and I was wondering if anyone could tell me what it means.
HRE
E7SC <- reguesstimate
35.0/4086
5560-KA
Thanks a bunch.
Antonio.
Spring ID
E7SC means its an 87 part, and it is made for the tbird/cougar
Spring ID
i know that part. :P what about the other stuff? can the spring rate be determined from this?
Spring ID
The 35.0 is the initial spring rate in N/mm.  That converts to 200lb/in.  That's a pretty standard spring rate for the Foxes.  Since all but a rare few have linear rear springs, that is the initial spring rate.  Usually they are 200-300# progressive.
The 4086 is the load rating in N.  That converts to 918 lbf. (Pounds force).  That's lighter than the original rear springs in my 84 XR-7 (944 lbf), but still much higher than most Fox Mustang rears, and even the SN-95's aren't that high, but they get closer.
Spring ID
coolbeans. thanks chuck. :D
