Topic: Want: Fuel pump connector, Throttle connection (Read 1347 times) previous topic - next topic
I've got an '85 CFI 232, C5.
Ok, I am needing:
* The plug that makes the connection between the fuel pump and the chassis harness.  (drop gas tank, plug on passenger side)
* The plastic block that the throttle cable and cruise cables snap into, which then snaps onto the throttle lever.
Do you still need these parts?  I should be able to help you out with both.
1987 Thunderbird 3.8. Sold :(
-as far as the fuel pump connector, go to your local ford dealer and ask for wiring pigtail #3u2z-14s411-nca.  this will give you a new connector that isnt so brittle.
-as for the block, best guess is the j-y.....
-stu
