Topic: Wiper Removal (Read 1419 times) previous topic - next topic
Wiper Removal
I have an '83 'Bird that I wish the remove the wiper arms from.  Followed the manual, arms up on windshield, pulled clip back and pulled up on arms, nothing.  Am I missing something or should I use more force to pry up the arms?  Any ideas?  Fred
Wiper Removal
I had to replace an arm on my cougar and I had the same problem. I took a pair of pliers to the small tab the haynes book says to pull out and gave it a good tug. It slides out farther than you think and then the wiper arm can be wiggled right off.
~1988 thunderbird~
In hibernation, waiting for spring.
Wiper Removal
i almost always have to use force. usually with the plyer method just mentioned.
Wiper Removal
Thanks guys, I'll be sure and use brute force and get it done.  Fred
Wiper Removal
you must slightly lift up on wiper blade end of arm to release tension then slide tab out once the tab is out the arm will sit on tab so that you can remove and reinstall easily.
