Topic: Best Way To Pull Out Head Studs (Read 2293 times) previous topic - next topic
i was just wonder what is the best toll to use to bull the studs out of a head or would any stud puller work about the same thanks
:flip:I GOT MORE POWER NOW:flip:
:mad:..BUT I NEED EVEN MORE..:mad:
I though that 5.0 heads were just bolted to the block with bolts and no studs.:dunno:
naw i mean the studs you bolt the rocker arms to
Oh my bad. I'm not sure if the studs are screw on or not. I never took em off. Perhaps someone else would know.
Should be screw in ones.  What year heads?
well they are 68' stlye heads and i figured out how to get them out thanks for the help if any one wants to know just let me know and i will post it thanks
try using a small pipe wrench.  but dont bite the threads if you plan on reusing them
what i did was remove the rocker arms and i slide a socket on to it then i put the pivot ball on top of the socket then i just screwed the nut down till it ripped out the stud it works great
