Topic: tail shaft bushing SOLVED (Read 6835 times) previous topic - next topic
where can you get one off the shelf?
i grab my drive shaft where is comes out of the tailshaft of the tranny and there is a lot of play.  Im gonna keep putting this off till one day i see smoke pouring out the rearvew mirror.
the bushings are very cheap but i cant seem to find em on the shelf anywhere.
for anyone who's like "wtf is this guy talking about"
the tail shaft bushing is what your yoke on the drive shaft spins against while it turns.  when this shim gets worn,, you will have a vibration and noise that sounds like its coming from the center of the car.
Re: tail shaft bushing
Can't you just have Advance just order one????
mine over here in wva says they cant get em.
ill probably just make one out of copper pipe and cut the lubrication slit by hand.
tranny shop says they can order it but i cant figure out why so many tranny shops consider it a long lead item.  seems pretty easy to get to and should be replaced every so often.
try rock auto.com they are fast cheap and have a good selection  they may have what you need
i found one ,, ill it will be ready for pickup this afternoon.
There are two different bushings, one for a GM T5 and the other for a Ford T5.  I took my tranny tail shaft to a local transmission shop to have it changed.  They told me it takes a special tool to R and R the bushing.  They only charged me about $20.00 to change it out.
Quote from: Johns331
 i sure hope not, ive only installed one and it lasted til the original tranny bit the dust.
advance dropped the ball on my order for the tailshaft bushing "KIT" so they call it.  Actually it is called the extension housing bushing but anyways Napa has just the bushing for 4 bux and some change.
i removed one on my old aod which was easy , just pry it out.  the new one was installed just as easy by using a zip tie located slightly off center to compress it.  I just gently tapped it up in the hole and aligned the slot, cut the zip tie and resumed using a wooden tool to finsh seating it.
im pretty sure the same install practice applies here as what would apply if you install a cam bearing.
i would not mind seeing that tool, might be able to make it if i knew what it looked like.
Re: tail shaft bushing SOLVED
that really hit the spot,, new tailshaft bushing installed.
symtoms of a bad bushing:
1 side to side play where drive shaft exits rear of tranny
2 a rrruuuummm  rrruuummm noise coming from center of car and front end parts still dont fix the problem
3 excessive tranny fluid leaking out tail shaft housing even after tailshaft seal is replaced
4 going thru too many tailshaft seals cause they end up coming off
I have no more vibration anywhere in my car.  Its so quiet that im now bothered by the wind i hear across the doors and windshield. :)  Oh well,,i guess thats what the radio volume  is for :ies:
parts replaced to make it all quite again
ball joints
wheel bearings with shim stock on the inner race of inner bearing
tie rod ends (which ended up concluding to a whole rack)
tail shaft bushing (really called extention housing bushing)
if anyones interested in the how to's on this, just reply.
special tools are call for if you want to go that route or it can be an easy diy project that takes about 2 hours for a lesser experienced person.
there are two types of tailshaft bushings i am aware of.  One is split longways and the other is solid.  if you have the solid type , the extention housing has to come off.  if you have the type like i did which is cut longways, you dont have to remove the extention housing.
I did mine the easy way...... First I bought two bushings, then cut approx 1/4" off one. Next I slid the full and the cut bushing onto a D/S yoke and slid it into the tranny. A few good licks with the hammer and the cut bushing was in place, leaving the original pushed approx 1 1/2" back into the tranny. The other "full" bushing was discarded, as the taper on the yoke caused it to distort badly.
BTW  Been like this for over 2 years now, still just fine.
you turkey!!!!!!!
 thats slick :)
why'd you wait till now to share that trade secret?
He wanted you to suffer? :p
This *might* be in my future, since you mentioned all the front end stuff and it not helping you. I'm hoping to clear up my problem sooner.
Quote from: Bird351
naw,, say it aint so tom :mad:
just had a senior moment,, right? :grinno:
I need to do the same thing on the T-5 in the Ranger....
TurboCoupe50....am I missing something..or did you do this with the tranny still in the car and left the old bushing inside the trans?
Hey guys and gals, like the new site,,, anyway my tranny has this same vibration,where can i find one of these bushings?? looked up napa and advance on the net, neither shows this bushing, should i look under a stang or something else?? thanks
hey chuck, im not tom but i got what he meant so here goes
you leave the old bushing in.,, buy two new ones.
remove the drive shaft
cut about 1/4'' off your intended new bushing
slid your whole new one on the yoke
next , slide your cut one on the yoke
slide the yoke up onto the outputshaft and work it like a slap hammer back and forth
that ends up pushing out old bushing up inside the extention housing making enough room for the trimmed up new bushing.
remove drive shaft and the first bushing you put on the yoke and toss it.
your old bushing is sitll barely haning on inside and even if it does come off,, its just gonna spinn round and round till hell freezes over.
leave the tranny in
yeah, i had to read that a couple times also to let it sink in and picture what he meant.
Flippinbird
you can get the "extention housing" kit at advance for 11bux but they have to go to the books.
napa sells just the bushing for like 4 bux.
