Topic: truck wount start (Read 1651 times) previous topic - next topic
truck wount start
hey, at least its a ford truck :p
its a 79 f250 with a 351m. dam carbed truck never liked to start in the winter, and now its compleatly not starting at all (crank no start). im makeing sure its getting fuel, and when i tested for spark it came up negative. im told its got dura spark ign. but hey... im not to swift with these carb thing-a-ma-jigs... so any help would be greatly appriciated.:bowdown:  any tips on what to check after fuel and spark? and it does have new cap rotor wires and plugs. i do have a wireing diagram for the engin compartment.
truck wount start
Have you tried spraying some ether into the carb? How about checking to see if the starter is working right?
truck wount start
yeah, i tryed spraying the  starting fluid with cylinder lube (gotta love lube) and the starter works fine. it will crank all day but never starts, or hickups
truck wount start
Is your coil working? Check to see if it is. If that isn't it you might need a new distributer. I don't know much about the dura spark II so I don't know if parts can be changed on it or not.
truck wount start
you need a new ignition module aka: duraspark box
truck wount start
just curious, what leads you to believe that? then again, theirs not much that these old trucks have to go bad lol
Quote from: SLEEPER T-BIRD 87
truck wount start
definatly check the coil first, that duraspark box is probably  special order nowadays
truck wount start
Quote from: Manson
They fail almost as regularly as the dammed TFIs...
Make sure the dist is turning, those old Ms love to shear off the pin holding the gear on the dist shaft...
truck wount start
Quote from: Manson
it is the single most common reason for the early ford electronic ignition to have a no start condition.
they are about 20.00 at advance or autozone.
truck wount start
yeah I've tested many a duraspark box at autozone.  Dont just go to a junk yard and grab one.  There are like 4 diffenr't types.  The grommet were the wires goes in is a differn't color so at least its easy.
truck wount start
cool thanks, for 20  bux its a deal. and another check closer to a 20$ gift card.
truck wount start
Quote from: Manson
I got the 20.00  gift card today :D
when they raped me 10.00 a gallon for antifreeze:flame:
truck wount start
hit the nail on the head guys, it was the  box.  it was good to hear the sound of open long tubes again lol. thanx again.
truck wount start
Quote from: Manson
n/p i used to keep a spare with me when i drove my dads 77 f100 everyday. Cause they go out at the worst times.:giggle:
truck wount start
Lol the old 84 f250 has a spare wired under the hood.
