GM leaks Camaro concept sketches
Reply #41 –
Again my experience:
There are only two real engines builder for the 4.6. One of them is FoMoCo, the other sure ain't SHM (heard way too many horror stories about him). I'm referring to Renagade Racing in Florida. His reputation is well known in the MOD world and well deserved. Unfortunately he is expensive and rightly so because you get what you pay for. Due to the 4.6's advanced design (tight tolerances) not just ANYONE can build one even with a shop manual. What needs to be understood is this:
until the '03 Cobra, the 4.6 never had forged pistons. Forged and hyperautectic pistons have very different rates of thermal expansion/contraction. To build a 4.6L with forged pistons using regular 4.6L clearances (and most builders aren't skilled enough to even get close to the factory spec) you're already headed in the wrong direction. The most you may get is 20,000 miles out of it before the pistons start to rock back and forth in the bores unless it was built by the right people. So you can't just go to any engine builder. Even the '03 cobras have this issue because they are the first cars with forged 4.6's and it hasn't been perfected yet (the pistons were spec'd too tight from the factory). Find me an engine builder who can put a forged 4.6L block together for less than $6,000 and have it be as durable as a factory Ford one and I'll be the first on their order list. Or if Edelbrock or AFR would make some nice SOHC heads (or even DOHC) I'll be looking through autotrader to get another 98 LSC to modify it. As far as running 400-600rwhp all day on stock internals, my view on that has already been stated. You are taking a gamble. I seriously doubt that an '03 mach one makes 300 rwhp stock. That means that the engine would have to make at least 340 bhp. I have never seen one dyno'd in person before, but I have seen a few marauders (exactly the same engine, slightly different exhaust) and that car makes 240rwhp on it's best day. I have put 6,000 miles on my GTO so far and have lost about 1/4 of a quart of oil and it was purchased with 10K miles. It also has 5 1/4 mile passes and 3 dyno pulls on it. You can't say that some engines don't leave the factory with defects (like the 2000-2001 Crown Vics that have camshafts that were breaking).
