Topic: Solid Motor Mounts? (Read 3383 times) previous topic - next topic
Solid Motor Mounts?
Does anyone know if there is a company out there that makes solid motor mounts for an 88 cougar with a 302?
Solid Motor Mounts?
You can use solids made for ruststangs or go with polys.
Why do u want solid?
Solid Motor Mounts?
Quote from: SirChirpAlot
Not with an 88 he can't.....
Solid Motor Mounts?
no he can't,
Solid Motor Mounts?
Nope...
Chuck, now would be a perfect time to hawk a set of your customs...
Solid Motor Mounts?
Quote from: TurboCoupe50
If I was taking orders at the moment I would ;)
Solid Motor Mounts?
Why dont the mounts fit?
I have polys in my 85 and had them in my 83.
My 87 T bird has 5L HO from a stang and i had stang mounts in it.
I havent look to hard at the TC yet to see how K member looks.
Solid Motor Mounts?
The 83-85 Kmembers use the same mounts as a Mustang.  The 86-88's have a different K-member and thus different mounts.....
Your 87 5.0 should have the same K-member as the TC.  If you are not the original owner of the car, then I bet it was swapped.
Solid Motor Mounts?
Could have been swaped i realy dont know.
I pulled motor trany out of that car when it was wrecked and it was reused in my Cougar
Solid Motor Mounts?
All '86-'88 Birds/Cougs have a flat pad the motor mounts sit on, unlike the 45* angle pad the Stangs and earlier Birds/Cougs use...
Solid Motor Mounts?
I was under the hood of my TC and i seen hows its diffrent.
Big Hammer and Flame Wrench will fix this prob.
Solid Motor Mounts?
yah i am going to have to pass on that one.  I guess i will just have to use the stock mounts with one of those competition engineering torque straps , Thanks
Solid Motor Mounts?
Solid Motor Mounts?
Speaking of which, Chuck when are you going to start the official sale of those things?
Solid Motor Mounts?
Probably just after the holidays/first of the year.
