Topic: Injector woes?? (Read 1736 times) previous topic - next topic
Injector woes??
Ok my car has been acting a bit strange lately.  If I start the car after its been sitting all night it will fire right up and idle like a new car.  Well If I drive it then let it sit for a short time, say 15 minutes when I start it again it will bounce around like its running on 4 or 5 cylinders.  It only does it for a couple of seconds before it smoothes out but it never gets perfect.  At lights it runs rough.
I'm convinced this is an injector problem.  When I shut my car off it smells like gas.  I havn't pulled the plugs yet to read them but it has to be running rich.  yet I got 26 MPG on the trip from ohio to florida!  Its kinda getting worse and not fixing itself so I'm asking you guys!
Injector woes??
I would check the o-rings on the injectors.  I had a similar problem and that fixed it right up.
1987 Thunderbird 3.8. Sold :(
Injector woes??
Ok guys, will the injectors out of say a 96 or 97 bird with a v6 work in my 88?
Injector woes??
Mines TBI 5.0, so i don't know about your six banger injectors.
So I thought i'd suggest checking the control module. The only grounds for that suggestion is my belief that they act up when they're warm.  Maybe it's not controling the ignition like it should.  And plus it's a real easy test at a nearby Autozone.... GET IN THE ZONE!  AUTOZONE! :hick:
:pics-stfu:
 Project Thread with pics
Injector woes??
The newer style injectors have different pigtail connectors so you would need a harness adapter for them to work.  I believe they are different flow rates as well......
Injector woes??
hell, any gray top injectors will work. SO 5.0, 3.8L, all those
Injector woes??
Before you spend a bunch of cash on parts, try cleaning your throttle blade & IAC passage, and run a jug of injector cleaner (I like Berryman's) through the gas tank.
Injector woes??
No I believe it to be more involved than that.
Injector woes??
tps maybe? or clean out the throttle blade like jimfulco said, how long since a tune up?
