Topic: When it rains, it pours. (Read 3043 times) previous topic - next topic
Or when it snows, the antifreeze pours from the heater core :macgun: Why is it that this only happens when you need the heat most???
1987 Thunderbird 3.8. Sold :(
I remember jcassity saying he hooked his heater hoses to the AC evaporator. He never planned to use the AC.
My Heater Core does it too. Still works fine, but the antifreeze boils when it hits the block and you suffocate on the fumes. Anyone know how to fix it? I cant find the leak anywhere, searched for an hour today.
Quote from: softtouch
I completely forgot about that!  I remember the post, but it never occured to me at a useful time (like now).  It's a  good thing some people remeber these things...
the antifreeze pours from the heater core  Why is it that this only happens when you need the heat most???
Did you run the heat this past summer at all?
Quote from: amooset
Because that's when you turn the heat on. ;) This is like asking why your headlight burned out at night.
I already did my heater core this year.
Its actually not a bad job, i did it over the course of a few days, just because i didnt want to do it all at night. One evening, i took the console out, the glove box, the kick panels, pillars, and speaker grills out, the next day i pulled some other stuff out, dropped the column, did the dash, changed the core, put most of it back together and drove it around for a while. Next day i put it all back together.
Quote from: Tbird232ci
If I didn't tackle it all at once, I'd more than likely lose a couple things in the process or forget the little techniques used to remove something in the first place.  I think I'll just use the cheater's way out (using the a/c) for now until I get my exhaust finished.
Took about two hours to do the one on my 20th, not that bad really.:D
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
took me 11 hours in the dead of winter, like 20* outside or less. Did it in the spring and it was a 3 hour job.
A word to the wise.  If you have a column shift, make sure the car is blocked at the wheels.  Dropping the column can sometimes shift the car out of park.  One time this happened to me and I woke up to find my car about 200 feet from it's original spot across the yard.
Quote from: cougrrr302
  Hmm I had a probelm like that, and it ended up being a cracked timing chain cover.
Well, she's temporarily fixed.  The a/c condenser works quite well, I just have to turn the temp all the way down to get any heat :D .  Took me about 30 minutes with a belt change as well.
Well that reminds me that my heater core is dead in my T bird.
Something else to do after i drop the motor in.
Wonder if that A/C evaporator trick would work on one with the automatic temperature control.  You know, the thing that blinks 75--75--75--75 all day long.
