Topic: Mustang H.O computer in T-bird (Read 3335 times) previous topic - next topic
Well I got my computer today. Put it in the car no more idleing problems:bowdown: but I did notice it raised the base timing 2 deg with the spout out a bit with it in.
before
12 deg out
22 deg in
now
14 deg out
30 deg in
car seems to run much better and everything including the trip minder still works. How much more agressive are the spark maps in the mustang computer? I now have detonation around 2,500 at WOT I am going to start back at base timing and go from there.:D
The EEC has nothing to do with base timing, set purely by the distributor...
Don't have a clue as to the actual timing curves output by the computers, but most HOs can take 13-14* advance(with premiun fuel).
Quote from: TurboCoupe50
they must be alot more agressive curve. Car feels better I just need to turn the timing down some before i lean on it hard:D
At least it idles better now:flame:
I'am a little confused. How did you put this HO computer in your SO? What else did you do?
James
Quote from: srv1
James
19lb injectors.
did you rewire anything, or just plug it in? I have a possible bad computer, and a SD HO puter laying around......
Quote from: Haystack
didnt touch a wire. swapped in the 19 lb injectors
I take it that you used the 86-88 Mustang HO computer?
Quote from: Lx-tasy
 speed density yep:D
Actually in this case you should move the pins for the injectors at the EEC plug... You have a cam with 15426378 firing orede while the injectors are firing 13726548.... But when you move the pins it confuses the EEC and causes some of the cylinders to go rich and some to go lean...
Better leave it alone and just swap in the HO cam...
I say rewire them just to see.
yeah i need to get the cam in it:D  and the heads ... and the intake..
man i need to do alot:flame:
I am going to leave it alone it runs a-ok as is:D
Just a little off topic here...I had my base timing at 14* and I run on regular 87 octane everyday of the week with no problems.  Also, with the base timing set at 14* it will jump to around 36-38* with the SPOUT connector plugged in...seemed a little high to me.
Quote from: Sick88Tbird
Thats normal for the timing...
Suprised it don't ping on 87 though,consider yourself lucky...
