Topic: my sport (Read 2652 times) previous topic - next topic
my sport
Well let's try this again, been trying to get these pics on for awhile . this is my 300.00 bird, bought it around a year ago,let's see if this works?????????
never mind!!!!!!!
my sport
If you wanna try sending them to my email, I will see if I can post them for you. email in sig.
my sport
For a buddy of mine ;)
looks pretty good, very clean. Paint the tc hood!
my sport
It does look good. Is that the original paint?
And as Haystack said, paint the hood!
my sport
Looks similar to what my red bird used to look like before i painted the molding and put a TC header panel on it.
my sport
For $300 that's a hell of a car man....leave the hood flat black...nice throw back to the muscle car days.  Just make sure you seal it...my black primer is oxidized as hell now...even after countless hours of wet-sanding with 2000 grit sandpaper and rubbing/polishing compound.
my sport
those wheels are beautimous! :grinno: uhm... i'm assuming it didn't look like that for $300. O_o?
my sport
Its kinda crazy, i dug up some pics of mine when it looked just like that, just had more chrome and less shine on the paint...and the black wasnt as black
my sport
Very nice.
my sport
nice example of a nice clean car! good job.
im glad too see there are more guys out there that care about the fox tbird/cougar breed enough to take good care of one!
~John~
my sport
A+
my sport
Always did like that shade of red. Very sharp.;)
[SIGPIC][/SIGPIC]http://www.fquick.com/slicksport88
88 Sport - 5.0HO, Mass Air, A9L, 73mm C&L meter, BBK CAI, 255 lph pump, 1.7 roller rockers,Professional Products damper, Chuck W motor mounts, BBK shorties & H-pipe, Flowmaster 40 series, 8.8 rear w/3.27's, 93 Cobra M/C, BAER 13in. drilled/slotted rotors front and back, cobra calipers, Russell braided brake lines front & back, C/C plates, 03cobra rims, 255/40/17 Nitto 555's all around
my sport
Clean machine.
my sport
Thanks guys for the comments,when i got the car it was NASTY!!, needed alot of cleaning, the wheels were black, the paint(original) looked pink,interior was filthy but in great shape, little green carpet cleaner took care of that.Everything works except the cruise. I have since then tore the engine down, needed new bearings and oil pump, k&n, removed silencer, true duels, no cats with 3 chamber flows,crossover, wires, plugs, injectors, bumped the timing, new tires, shift kit, jammin stereo with 750 watts of power (not a whole lot), 176,000 and still runnin strong(knock on wood), thanks haystack for postin pics !!  I don't know why I can't get pics up??
my sport
It can be a pain, just get a photo bucket and upload them there then use the html thingy and paste it in your reply. I gotta give you props though. Very nice looking. v-6,v-8? wait sports are v-8's sorry. Any thinking twoards the H.O. conversion?
