Topic: 19lb injectors on stock S.O ecm ? (Read 2104 times) previous topic - next topic
Well today i swapped out my old worn leaky stock injectors for a set of late model 19lb injectors...
now i have a sputtering idle....is this a product of more fuel ?
car feels stronger throughout the rpm range and smoother.No miss or issues under load or off idle.
I am waiting on a mustang ecm to arrive for it I am aware i will have to move the injector plugs due to the firing order.What else should i expect? Will it fix my idle problem?
OK, I'm gonna go on limb and say you have an SO cam still due to the fact you have an SO ECM.  On a bone stock SO engine 19 pound injectors with the factory fuel pressure regulator is just too much gas and not enough air or cam or cylinder head.
You can run those 19 on an SO computer but, you need the engine upgrades to make it necessary OR an adjustable fuel pressure regulator.
The stock fuel pressure regulator on return style Ford fuel injection systems is 39 PSI.  Raising the fuel pressure on a 14 pound injector to about 60 PSI will allow it to flow as a 19 pound injector would at 39 PSI (provided you have enough fuel pump to feed it)
With the 19 pounders on a stock SO I would get an adjustable regulator and set it for about 30 PSI with the vacuum line disconnected.
This chart shows how pressure affects injector flow rate.....Remember, you need enough pump to support the fuel pressure/flow and a bigger injector with less pressure is better than a smaller injector with more pressure
Quote from: Paul Flockhart
thanks ,
the car has 1-5/8 long tubes, an h.o upper and lower intake and 60mm throttle body,mac lers off road h pipe, 3.73 gear, a 255 fuel pump, underdrives etc,
I am fixing to do
b303 cam, set of ported e7's, trickflow intake, mustang ecm ,
On a interesting note i unplugged the act sensor and it idles better but still not great.
Paul is correct...
you can create a vaccum leak of a couple hundred RPMs, to lean out the idle a bit.
Also it it NOT necessary to move the injector pins in the EEC plug. The computer determines firing order, not the harness...
Quote from: TurboCoupe50
Paul is correct...
cool anything else to expect? I know we have talked about it before. I would like to keep the factory trip minder also.
My car is running at about 32lbs of fuel pressure on an HO motor with stock(HO) fuel pressure regulator.  I thought it was a result of bigger injectors and the pump not able to keep up, but the drivability is great and the fuel pressure jumps to about 40-42lbs with the vacuum disconnected.
I agree, the 19lb injectors are too much for a stock HO.
Quote from: Sick88Tbird
And thats exactly what the pressure is supposed to do...
you can create a vaccum leak of a couple hundred RPMs, to lean out the idle a bit. ...
I may try this as a temporary "fix"
Like Tom said.  Your pressure goes up with vacuum disconnected.  You should always set your pressure with the vacuum line disconnected.  It's like setting base timing....Always disconnect the spout.
A bone stock HO will respond well to a fuel pressure drop of 3 or 4 PSI.
Quote from: SLEEPER T-BIRD 87
thanks ,
I am fixing to do
:yuck: what a wonderful day:nono:
YOU DUMB ASS!!!! Don't you know that only works on Mass Air????
UHHH.... OH yea, I forgot...:shoothead
I remember when I changed my injectors cause of a cracked tip. Ford dealer sold me a set of 19lb (they said they would work and i didn't know any better then). When I fired it up within seconds my eyes were watering from the exhaust. I could barely keep it running at idle but once i gave it throttle she was good. Needless to say i was pissed when i found out they were supposed to be 14lb. :mad:
[SIGPIC][/SIGPIC]http://www.fquick.com/slicksport88
88 Sport - 5.0HO, Mass Air, A9L, 73mm C&L meter, BBK CAI, 255 lph pump, 1.7 roller rockers,Professional Products damper, Chuck W motor mounts, BBK shorties & H-pipe, Flowmaster 40 series, 8.8 rear w/3.27's, 93 Cobra M/C, BAER 13in. drilled/slotted rotors front and back, cobra calipers, Russell braided brake lines front & back, C/C plates, 03cobra rims, 255/40/17 Nitto 555's all around
