Topic: Ultimate 2.3 N/A mods (Read 3167 times) previous topic - next topic
if i don't get some notes on what to do with this slow POS, i'm gonna boost it...
i wa thinking just a cam or so,
i don't really know
i just glanced over some thing about using an MSD box, you should increase plug gap ??
i'm running the MSD 6a in my 89 mustang,  all stock  minus the MSD box, and a lowes made cold air intake
i think your gonna have to boost it. i knew a guy in a auto vert 4banger mustang and it was slower than my hyundia accent. then again, he was probley border line retarded... anyway i cant see many things that you can do and still obtain alot of power for the ease of finding a junkyard turbo car and swap'n the parts.
yeah. the 2.3 in my ranger is very similar asside from the newer ignition. its a friggin slug. chances are though, if you want to go boosted you might as well go with a turbo coupe engine with the forged pistons/stouter SB.
personally though, the single best mod for that 2.3 would be a 5.0
better to put the time, money and energy into something like that rather than messing around with the 2.3 thats in there. dont know how long it would last with a turbo......
~John~
yeah, boost it or ditch it. I cant think of alot you could do that wouldnt kill gas miliage.
want a nice n/a 2.3
have the head cut .150 thou
order up a cam with around 300 deg adv duration
and around .600 lift
port the head
have large valves put in
grab a 390 4 brl carb
and esslinger intake
a long tube header for a pinto
Same combo many dirt track racers use. Now all you have to do is twist it 8,000 rpm :)
want a nice n/a 2.3
port the head
cool, at least its an answer to the question. sounds expensive though....
~John~
i think i forgot to mention that it's an 89 mustang....with EFI, so no replacing carb,
but couldn't i just get a better cam, like a roller cam?
i'm not lookin for 100+ more hp, i'm lookin for 20-30, like cam, gutted upper intake, advacing the camshaft 4* or some thing ?!
ohh, and if i were gonna do a motor swap, i'd probalby just do the 460 swap, and screw the 302's.. but i'm not, i need the milage,
my turbo 4cyl stang gets about 20 MPG, all the while...whoopin butt
well if you look'n for that, you can PORT the upper and lower, gutting it will get u power and no torque, these cars fall on their face at low rpm, i cant immagion without a turbo... power head makes probley the best head for the car, and its just a stock head ported to hell with big valves so im sure a shop can match it pretty close for alot less. that cold air intake should be good for some, and you can get a header for it still and do up a exhaust. that should get u close. maybe a afpr.
edit, you may want to look into gears or 5speed swap for gearing
the only reason i want to leave it an automatic.. is cause i'm lazy, and my turbo stang is allready a t-5,
gearing my be an option...
wht gears should i go with ? to maintain gas mileage, and power ??  3.73? 4.10
Quote from: 460 turbo truck
it should have at least a 3.42 in it now. 4.10's with an aod will help.
id say a a237 cam and a long tube header would give you the 30-40 h/p you want and stay somewhat reliable .Maybe swap on a 60mm throttle body and a adj fp regulator.
okay, so adjustable fuel pressure regulator, better cam, exhaust header, ported upper and lower, a set of 4.10s
(what axel should i have, a 7.5, or an 8.8? )
and probably a better exhaust,
any one have some links to these things ?
thanks
it will have a 7.5
the links to most of the stuff can be found on http://www.turbotbird.com in venders section, im not sure about the headers for the na2.3 tho, the ones i have in mind were made for a turbo. afpr i got from here http://www.jdsperformance.com/
Don't mean to piss in your cheerios, man, but I've done the whole 2.3L n/a thing and it's just not worth it.
For starters, you can't put a cam in any n/a 2.3L below a '91 ('89 for the rangers) because they were speed density.
Secondly, bolt ons just don't do anything for the n/a 2.3L (probably because it only has 88 hp)
And third, even trying the usual tricks of upping compression and all that generally do not get you enough power to be worth it.
In my old '90 2.3L mustang, I had a header, exhaust, cold air intake, adjustable fuel pressure regulator, underdrive pulleys, and 3.73's in the rear end (came that way when I bought it). I even did some tricks to reduce weight (pulled sound deadener, put battery in back, ditched AC). Even after all that, it still couldn't get out of its own way, and it was a 5 speed.
Oh, FYI, your car has 3.73's in the rear if its an auto. Also, expect that A4LD to blow up, because it will sooner or later.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
well, FYI, the tranny's just been rebuilt, so it's not gonna fail, and i'm pretty sure if i do some head work, and up the comp, header and the throttle response kit, and the TB swap, it'll be a little over 100, which is fine,
i just got owned by a rabbit 81, not even a gti,
and i don't see how your saying this is a speed density, there's no mass air flow, or vane meter's on the 2.3 N/A's,
i haven't seen any under drive pullys for the 2.3's maybe you could fill me in ..
as for timing..i could do the esslinger kit..and gain a few...
i'm not lookin for track times... i'm lookin for a...beat the old lady on the scooter...
if i wanted track times...i'd hop in my 75 dodge with a 400 turboed...or my 89 2.3 turbo stang...
i'm not lookin for top speed, i'm looking for a little more speed..than turtle
