Topic: axle swap... (Read 1248 times) previous topic - next topic
axle swap...
-am i correct in my reading research????,
can you directly swap a mustang rear axle, 94-98, the narrow one, with abs , into a 87-88 turbo coupe without too many mods?!?:sleep:
axle swap...
They are the same width.
Not sure about the ABS if you're wanting to keep it.  You gonna use the SN-95 brakes?
You may have to do some fiddling with the brake lines between the axle and the body depending on what year SN-95 you use.
The axle will bolt directly into the car w/o mods, it's the ancilliary stuff that will cause issues.
axle swap...
-yeah, wanted to keep abs, use the sn-95 brakes.  seems easier to swap whole axle assy for 5 lug conv., than to change axles, rotors, etc.  i know they are not vented, and may have to find correct hoses, but other than that, what else????
