Topic: need help with engine trouble (Read 1062 times) previous topic - next topic
alright i think i dug myself pretty deep this time car wont start and there spark but the problem is the throttle body injectors are pushing way to mush fuel so i unplugged them and they still flow fuel ? i replaced both of them and the throttle positioning sensor and its doing the same thing does anybody have any ideas ?
thanks
daniel
update sorry its a 1983 LS cougr 5.0
sounds like they have a bad o-ring or one was left out or maybe in the throttle body?
lets start with what year and engine? the fuel injectors are basicaly electronicaly controlled valves switching from off to on letting presurized fuel out in a fine spray. did you get a fuel pressure gauge and check the fuel pressure? the regulator might have gone, you said you replaced the injectors right? are they leaking from anywhere?
