Topic: will this work (Read 3064 times) previous topic - next topic
will this work
scored an aod out of a 92 mustang. is it a direct bolt on in my sport or is something different?
88 sport 308 e-303, ported e7's, cobra intake, cold air, under drive pulleys, full exhaust, t5, 373's, smog pump removed, 255 pump, pressure regulator.
                        :birdsmily:
will this work
Not sure but that may be an AOD-E which if it is, it requires a computer to shift it.
will this work
Same tranny, bolt right in. I don't think the fox mustangs ever had the aod-e.:D
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
will this work
Quote from: cougarman
Not till the '94s anyway... (OK they are SN95s)... Still basically a Fox...
will this work
one last question? I calles a local installer and he told me I would have to change the tailshaft in the tranny for it to work becquse the mustangs taileshaft is shorter. any truth in that?
                        :birdsmily:
will this work
Quote from: svtbird
I thought all passenger car aod's were the same except the aod-e
will this work
The Mark VII got a longer tailshaft, but the Mustang one should be the same as the Cougar/Tbird one.
will this work
You don't have to change it. The Mustang and T-Bird/Cougar AOD's have identical sized tailshafts. The Mark VII one is longer.
will this work
then you run into the whole floor shifter column shifter thing.
will this work
Quote from: CougarSE
well his info said he has a 88 sport, so he should be set to go.
will this work
Exactly...it's virtually the same transmission. The only differences that my mechanic has ever found between a Mustang AOD and all the other AOD's is the addition of a few more clutches for firmer shifting. And that can be done to any AOD.
will this work
thanx for the help guys. i guess he was just tryin to beat me out of some money.
                        :birdsmily:
will this work
the B overdrive servo also . and his 92 will have the "beter" valve bodie design
will this work
one final question. ive decided to try to do it in my friends garage to save alittle cash. that being said, he said hes never done it in a Ford and is kinda unsure how easy or hard it may be. does anybody have like a how-to diagram or something that we can maybe use.
                        :birdsmily:
will this work
make sure to check the speedo gear. I know mustangs use a cable drive speedometer while the tbirds have electronic senser, i am unsure if all stangs had it though.
