Topic: Fuel injected n2o users Problems........ (Read 1388 times) previous topic - next topic
got some problems...................................here is the setup
edelbrock performer selonoids
N.O.S fogger 2 nozzle
-4 to fuel selonoid from schrader valve
-4 feed to n2o selonoid
N.O.S 61 down from 62
FUEL 57 up from 35
What I am having problems with is severe detonation wich sounds like a rod knock.decrease the fuel jet and it gets worse the larger the fuel jet the less noise.So I have increased the fuel size until it has gotten quiter :nono:
timing is at 12*deg initial on 93 octane gas
Is this happening throughout your entire RPM range?  Your computer (if you still have EEC-IV) might be giving too much advance.....
Quote from: Paul Flockhart
Very likely, need to pull the timing back to 8* or so... Is this a SO 5.0??? If so likely you need to jet it 2-3 sizes richer on the fuel as well.. Or pull some of the juce.
Assuming a SO 5.0 does it have the stock pump?? If so it will have to be upgraded, they are only 60lph to begin with. Probably less with age.
yeah I worked on it today.......
ended up with 26* total timing insted of 32* total
had to change the fuel pump to a larger unit and now all is ok.:D
still have some very light detonation so i am going to swap in some colder plugs tommorow.....
I blame most of it on these e6 heads:flame:
what plugs are you running?
Ryan[/i][/COLOR]
1986 2R[/b] SVO
1984 T-Bird 5.0 (In Hibernation since 10/96)
It has just a set of stock replacment motorcrafts in it.. Ive got some a few ranges cooler to put in it.
Quote from: TurboCoupe50
speaking of fuel pumps it had the oddest on i have seen on any fox chassis car... A bosch pump with a pulsator on top and a 1/4 inet and a huge sock on the end ....It was about twice the diameter of the 255 walbro i put in its place..
Quote from: SLEEPER T-BIRD 87
Yea my '87 Sport had on of those.... You just about can't hear them run...
Also unless you have a MSD or something similar, close the plug gap down to .030-.032... Mine just bucked and spit till I did.
yeah thats on my list today.  I wish the rest of my parts would show:D I picked up a set of e7's and a b cam  and a stang puter:flame:  I am working on a new intake based on a truck lower also ;)
