Topic: Heat problems in 86TC. Please help Its 17deg out (Read 3113 times) previous topic - next topic
Well i have don'e everything i can think of to get the heat working in my TC and still hardly anything.
What i have done so far is: A complete system flush and backflow through the heatercore, added new antifreeze, checked the heater cables and made sure the flapper is moving as it should on the heaterbox. i just don't get it. the car seems to heat up just fine. it blows air good just luke warm. Any ideas
RIP 1986 Turbocoupe
1988 Mustang GT Show car/weekend racer
1986 Mustang T-top coupe The 2.3T project
1977 F250 400 4wd Fun in the mud
1997 Honda CBR F3 For when i want to make everything else feel slow
Check to make sure it has a thermostat installed.:D
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
opps should have added that i installed a new 192deg t-stat cuz i thought it was bad.
RIP 1986 Turbocoupe
Are the heater hoses getting hot?
yep, both hoses are getting hot and the motor itself seems to warm up as it should, the cooling fan cycles as well
RIP 1986 Turbocoupe
I had this same problem last winter and found one of the metal coolant lines on my 5.0 that runs under the upper intake was starting to collapse on a bend.  The inside had started to rust out and there were no signs of leaks.  My guess is the metal had gotten really thin and for some reason kinked up causing a blockage.  My hoses were getting hot but, they were not getting enough fluid.
You could also check for a pinhole in the hoses too.  I've seen it where hoses have a pinhole that won't leak at idle but, they will leak if you give the car a little gas causing the lines to get a little pressure.
check the radiator cap.if it doesn't pressureize enough ,it won't blow hot.
i've replaced the cap with a new one at the same time as everything else. could be a limited flow thing i know it being a turbo motor it has coolant going through the turbo and the oil cooler but i have tried to blow air through all the metal lines and everything seems fine
RIP 1986 Turbocoupe
Sounds like you've pretty much have it covered... If the controll linkage is OK(going fully to the heat mode), likely the problem is a partally blocked heater core. Several times foward & reverse flushing it with a water hose may help, if not you'll need to repl the core.
In situations like this, just run the heater blower on the low speed. You'll get more heat, as the high speeds will blow the air through the core without heating it...
that sounds like you are right. Im going to try flushing the heater core a couple times again and deal with whatever happens till spring i guess. Thanks alot guys
RIP 1986 Turbocoupe
My car is doing something similar. The temp has really dropped around here and I noticed the car wont heat up like it should. Just mediocre heat from the heater core and the engine temp takes a LONG time to rise, and even then it is not all the way. I am pretty darn sure the fan clutch is always engaged. Even when the engine is cold and at idle, the fan is on blowing a hell of a lot of air throught the radiator. Something easy to check for ya.
I am still going to say the thermostat is bad.Even though it is new doesnt mean it is good.
thanks army guy but it has an electric fan.
And as far as a bad T-stat. i checked the old one by placing it in a pot of water and  heating it up and it opened as it should so the original one was good while it was doing the same thing so i would think the new one would be good as well. Maybe the car just doesn't warm up being this cold out. I know if the temp is up in the 30's or 40's the heat seems to work pretty good.
I had similar py heat in my 91 2.3 n/a mustang
RIP 1986 Turbocoupe
