Topic: SO how much do stock replacement fuel pumps go for? (Read 2029 times) previous topic - next topic
So, my fuel pump took a dump the other night (at least I think). I was driving and the car stuttered and shut off. I had plenty of fuel and it would fire upon start up but I had no throttle response with the pedal to keep it running. If not the fuel pump what could it be? Ignition module? Does anyone know the price for a stock replacement fuel pump for an '88 5.0 bird? Thanks guys.
75-170 at autozone.
E-Bay.From next to nothing to a bunch.
They are not even worth it. Grab an aftermarket one ASAP.
Make sure it's the pump first...you should be able to easily hear it cycle when you click the key to the run position
75-170 at autozone
I actually priced one out just to see when I put my 255 lph pump in.  My 255 cost $140....AutoHole wanted over $300 dollars for the stocker which has a 66 lph flow rate.  BTW Walbro makes most of the aftermarket and stock pumps for these applications.
Quote from: Paul Flockhart
THe prices i quoted were from autozone.com with my zip
Run computer codes before you spend big bucks.  Mine sputtered & died & wouldn't run right, and it ended up being the TPS.
