Topic: rear seat (Read 1320 times) previous topic - next topic
rear seat
Taking the back seat out of my t-bird, its a burgundy cloth bench, any one wants it its up for grabs, you pay shipping,  also for any of you guys that have permenantly removed your seats I'm looking for ideas to seal off the area from the trunk, Not interested in any stereo equipment as Im triing to shave weight.
rear seat
Mine is out and I'll be using a bit of 1/16" ABS plastic covered with carpeting.  I'll have to work mine around cage bars and such.  I don't want to go with anything heavier.
rear seat
well if you dont have a place around you that sells sheet metal like i do, you can try hardware stores, they might have thin gauge aluminum you can carpet. the back is flat, but how will you do the seat pans? are you going to box it off or just keep it shaped like it is now? and will you be sitting anything on top of it, i have a habbit of tossing stuff in the back seat so you may want something that wount crack if a 5" thick automotive tech book hits it lol.
rear seat
Goint to stay shaped like it is Going to possibly mount a bottle back there and definately a fire extinguisher
rear seat
then  eather of the 2 would work. dont  know whats cheaper or lighter tho, i know thin plastic like chuck said is expensive where i saw it before, and rolled sheet metal at a hardware store or thin plates might be cheaper, but heavier... probley be best to browse threw the hardware store and fell the differences.
edit,
forgot to mension, last time i cut thin plastic sheets i had to be careful of cracking it(cracked a few times). i dont know if it was the stuff i used or not, but i did have a plastic cutting blade on the jig saw. so metal MIGHT be easier to work with.
