Topic: bullitt wheels (Read 2383 times) previous topic - next topic
bullitt wheels
can some one help me out i am looking into swapping in a sn95 rear into my 84" bird and i want bullit wheels well not actual one i want the 10" wide replicas out back does any know one if they will clear i know the sn95 rear is 3/4" and i want 9" up front but i will settel for 8" if they will fit the offests are
Front 18" X 9" Wheel has a +24 mm offset
Rear 18" x 10" Wheel has a +22 mm offset
help please
:flip:I GOT MORE POWER NOW:flip:
:mad:..BUT I NEED EVEN MORE..:mad:
bullitt wheels
I too am pretty curious about how big of a whel you can stuff in the front and rear, only I'll be using a TC rear end, most likely with 17" wheels.
Thanks,
Paul
bullitt wheels
a 10.5 wide wheel will fit with the s95 mustang offset on the rear. and s95 offset 9 wide will fit on the front also.
bullitt wheels
ok so what you are saying if i swap in a sn95 suspension all the way around they will fit did i get it right
bullitt wheels
Quote from: Sprayingsmooth
If you order the wheels with 94-up backspacing they will fit.
You will have to use the front spindles and brake kit. to get the centers in the front bullits.
bullitt wheels
Not to hijack the post, but does anyone know if 17 x 10.5" cobra r's will fit on the back of a 88 TC that now has Lincoln Mark VII rear-end components?
1988 Thunderbird Turbo Coupe
bullitt wheels
Ok, sorry....i found the answer in another post thanks to SLEEPER T-BIRD 87 in fact.  dang...wish it could work without losing the quads!
