Topic: Hood release repair (Read 5280 times) previous topic - next topic
Hood release repair
My hood release is still broken, and before I pull the fender off to try and fix it I thought I would see if anyone could help me with this.
I’ve heard that some have tried a different fix since the new hood release will be just as weak as the old one.  I’ve heard of a repair that involves shaving the rest of the broken plastic off of the handle bracket and reattaching it to the car with a couple of clamps that screw on and have rubber mounts or some such.
Does anyone know what I’m talking about?
Thanks.
Re: Hood release repair
what did it break off where the screw holes are? so its just floating around under the dash?
I fixed mine with 2 nice size wire ties... If you need a pic I'll take one later
i used a piece of steel bent like a sideways p except its open in the back, went rite over it, screwed it down works great.
Just do what I did,  remove the latch and get some hood pins!  :hick:
