Topic: 5.0 Pregunta (Read 1258 times) previous topic - next topic
5.0 Pregunta
So I was reading though an issue of Power&Performance that I picked up and there are these new cams by Comp. Cams called Ford XFI cams, but they are for the 5.0 stroker.  So my question is as follows:  Are all 5.0's technically 5.0 Strokers, or is it a 4.6 stroked up to a 5.0, or something like that?  What I am basically getting at is: Will they work on a regular 5.0?
Thanks,
Paul
5.0 Pregunta
"Stroking an engine is basically increasing the engine’s stroke length by converting over to a longer stroke crank.  Take for instance the 302 Ford.  A very popular conversion is to go to a 347.  The factory stroke of the crankshaft is 3.0 inches to make it become a 347 the stroke is extended to 3.40 inches in length. You need to utilize a different length connecting rod also.  Engine Factory can supply you a stroker with proper machining , balancing and notching of the block to make it trouble free.  The nice thing about this set-up is that all the modifications are done internally so your mounting patterns and accessories will all be identical ."
I am guessing  it is a 4.6 sohc
5.0 Pregunta
http://www.musclecarclub.com/library/tech/engine-types.shtml
http://www.fordracingparts.com/download/enginetips/enginetypes.pdf
http://www.fordtrucksonline.com/ford-6.8l-engine-specs.htm
If you go to the above sites and read the info you will see that the 5.0 that we speak of on a regualr basis has very little in common with the 4.6 and NONE of the parts will interchange.
The 5.0 Cammer is the new crate motor made by Ford racing.  It's rather pricey........
http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=8022
http://www.fordmuscle.com/archives/2003/11/cammer/index.shtml
http://www.jwfisher.com/sec-ford/FMC-engines/8m50d-cammer/default.htm
5.0 Pregunta
Holy lord, I new about the 5.0 cammer, but I never knew that it was that much money.  Thanks for the info.  That PDF is really helpful and cool too.
