Topic: QA1 Tubular K Member (Read 5125 times) previous topic - next topic
So, I want to get this QA1 Tubular K-Member for my 88 Thunderbird, and I was wondering if anyone here has any experience with this piece, and what they think of it. I can't think of any reason why this wouldn't work for a Thunderbird, but I figured i'd check first.
Thanks
Re: QA1 Tubular K Member
Griggs racing says their stuff works on Tbirds, but (as far as I know) they are the only ones who will say that for sure.
pro-five-oh
Ok thanks for the info, it's too bad their K-Members are so expensive.
I have a Maximum Motorsports K on by Turbocoupe, had to shim the four main chassis  bolts.  There seems to be a slight difference ibetween the Mustang and the TBird chassisin this area.
OK, so how about some experience with the QA1 model? (the one I'm considering using as well)
They all should be pretty much the same...
1987 cougar XR7 347 stroker FRP BOSS block 328rwhp 10.89 1/4mile @126mph ..so far..
2005 F150 5.4 vortec supercharged @15psi water methenol injected 450rwhp 14.0@98mph on 22's
*should*.. but when do things ever work like they *should*?
Until that Murphy guy crams his law up his arse, anyway.
Well,,, all the k members are made to fit a mustang so they all SHOULD :giggle:  have the same design... But I guess it depends on what year mustang they fitted it too.
I had a problem with the maximum motorsports k member on my 87 cougar, all the bolt holes lined up perfectly but I needed a 3/4 inch spacer to make it fit. Now...Johns331 only had to shim the bolt holes to get the same k member to work on his TC. :dunno:
OK, that just sorta proved my point.. :D but what I'm more concerned with is differences in quality, etc. QA1 is the one I see every time I'm browsing the Summit catalog.. (good bathroom reading.. lol) so that's the one I'm most interested in reading more about, in that department.
I had to use about ¼" in spacers to make it fit. Some of the differences between the Mustang and various years of the TBird/Cougar has to do with how much anti dive is designed into the front suspension, and what K member was originally  installed. I'm almost positive I took out some of the anti dive when I installed the MM K member, as the suspension is much more complaint in braking.  (high anti dive percentages tend to lock up the front suspension under heavy braking)
I plan on installing a tubular k-member on my 84.  The 3/4" spacer you are talking about is that between the k-member and the frame?  Also I plan on using the tubular A-arms and coil over shocks hopefully the mustang ones work
Quote from: 88tbirdproject
You get what you pay for...
I wouldn't trust my ass to a $250 K-member............
