Topic: Aod Oil Line Fittings (Read 1865 times) previous topic - next topic
Can anyone tell me what fittings will work in the oil cooler ports on a AOD transmission. I can find it anywhere. I have been told that its 1/4 npt thread but that is not correct. The fitting that came out of it is a straight thread of some sorts. I dont understang why I can't find any information on this. Not like this is an uncommon transmission. Orignal fitting design is a bad design in my opinion and always leaks at the orings where the hard lines go in. I want to replace it with rubber or stainless lines. I am sure someone knows what the right fitting is.
Thanks for your help
I have been told that its [COLOR="Red"]1/4 npt[/COLOR] thread but that is not correct. The fitting that came out of it is a [COLOR="red"]straight thread[/COLOR] of some sorts.
Put them together, and hit Google with "straight pipe threads".  :D
In 2004 I put some fittings on my AOD to connect it to some -6AN lines for my tranny cooler. I called TCI and they knew the fitting type and I ordered them from Summit Racing.
