Topic: cracked windshield (Read 1541 times) previous topic - next topic
cracked windshield
I have discovered Saturday that my windshiled has cracked for no apperant reason. It was not this way when I went home from work on Friday. The car has sat until Saturday afternoon when I moved the car from the driveway into the yard at which time I had seen the crack. The crack comes up 6" from the bottom, about 2" in from the passenger side and turns to come across to the drivers side. Is there any thing that I should check before having it replaced? I have subframe connectors on the car but these have been the for since late 2003 without creating any other problems.
Our web page
02 Explorer XLT 4.0L
04 F150 FX4 Supercrew 5.4L
02 Saturn SL1 1.9L
09 Vstar 950 Tourer
cracked windshield
Im pretty sure all it take is a slight chip in the glass and this time of year (at least where i am) the temps change drasitcally from day to night, when its warm in the day then cold at night Glass reasts almost like metal will constrict and extract a little that could be all it is.
cracked windshield
In my '87 Sport the windshield cracked because water got between the glass and metal and caused the metal to corrode. The corroded metal expanded and cracked the glass...
cracked windshield
This is exactly what happened on my wife's car last winter.  That darn car is on it's 4th windshield...
windshield out
Hi,
I replaced my windshield two months ago.
While its out is a good time to check your heater/AC parts.
I replaced the heater core and cleaned the condensation drain tube,
lots of leaves and stuff blocking it.
The 'dash out' is a bear of a job, my personal record is 6 hours.
But its a lot easyier if the window is out.
You can lift most of the dash up through the hole and put it on the hood while its out.:D
BobNorway;)
There are only two tools you will ever need:
1) WD40
2) Duct Tape
If it doesn't move and should, use the WD40.
If it moves and shouldn't, use the duct tape.
cracked windshield
:hick: I thought a cracked windshield was standard equipment on these cars!!!:D :flip:
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
cracked windshield
Quote from: BobNorway
Hi,
This is a great tip
cracked windshield
I have a "cracked" windsheild on mine,..... Well someone cant throw a tire OVER the car.  And I need a new one.We will just leave it at that.
