Topic: MSD....worth it? (Read 1928 times) previous topic - next topic
MSD....worth it?
I've been thinking about buying an MSD box for years, but never really seemed to have the spare cash to get one. Now that my engine is done I've started thinking about it again, but I'm wondering if it's really worth $160 for an MSD 6A. I've heard some people say that they didn't think it was worth the money. Just curious if anyone here has one and what they thought.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
MSD....worth it?
Honestly, they arnt worth the money as one of those "ill stick it on because i have the money" kinda mods
MSD....worth it?
Cant remeber if you FI or carb,  If yo have a carb yo have to buy a Dist to go with it,  makes it rather expensive,  FI good md will notice slight performance increase and better gas milage.  Oh If you go have a non comp contolrd vehicle get the MDS 6AL---same price with rev limiter.
MSD....worth it?
Quote from: t-bird85
Just reread this and relaised its way to late for me to be tying
RED forgot letters
Green-  "Who knows what this was supposed to mean"
MSD....worth it?
For your average street car even with a decent amount of performance mods you won't see any difference, but I think it would be a good addition if you wanted to dress up your underhood appearance.
MSD....worth it?
msd is a good upgrade.
an example we have been working on a 79 camaro with a 468 bbc car was fouling plugs out. swapped in a 6 box and had to jet it up 10 jet sizes.
carbed cars will benefit the most from it.
fuel injection also benifits with better milage, easier starting,better throttle responce.
and with high boost levels it helps keep the spark from blowing out.
MSD....worth it?
I guess I was thinking along the lines of not necessarily adding horsepower, but for smoother running and maybe improvement in mileage.
Garrett H.
Exhaust sound clip
Another clip
MSD keyword
The keyword with MSD is MSD.
Multiple spark discharge, if the first spark blows out the next one will get ignition.
If everything is perfect and every cylinder ignites every time then you won't get an improvement.
When was the last time everything worked perfectly every time for anybody?
With an MSD you can have a sticky injector, or a bit to rich mixture and get away with it.
You can put thousands into pistons rods cams carbs, but if you don't ignite then they are just pieces of iron(aluminum).
:D
BobNorway;)
There are only two tools you will ever need:
1) WD40
2) Duct Tape
If it doesn't move and should, use the WD40.
If it moves and shouldn't, use the duct tape.
MSD....worth it?
Yes Msd Is A Great Bolt On But Be Ready To Spend Money I Have A 6a Box The Distrbuter Wires And Coil And It Coast Me Around 500.00 For Every Thing And That Was With A 20% Discount On Every Thing Here Is A Pic You Cant See The Box It's Under The Over Flow Tank
MSD....worth it?
O Yea Dont Ever Lean On The Coil While The Car Is Runing With A Msd  Blaster Coil Becouse Trust Me You Will Know It
MSD....worth it?
I would just get the box, maybe the coil with it or soon after.
MSD makes a billet distributor for the 2.3L, but that's a lot more coin than I care to be spending right now!
Garrett H.
Exhaust sound clip
Another clip
