Topic: Confused (Read 2008 times) previous topic - next topic
Confused
I was looking around online checking out c6 transmissions, and couldn't find any definite print that said whether or not it is an auto or manual transmission.  So I come here humbly and ask: Which is it?  Does it come in both?  Confused, please help.
Thanks,
Paul
P.S. Tranny's are a bit of my weak spot and could use some research if anyone has any links or could point me in the right direction to really good tech articles, etc. etc.  I'd much appreciate it.
Confused
C-4/C-5/C-6 are 3-speed autos.
T-5 is a 5-speed manual.
Confused
Excellent, so it is basically what I am looking for.  They are meant for high HP/TQ applications correct?  And there is also a bolt on overdrive component for them as well, but that does run a little on the pricey side.
Confused
Got a link to that or any info on it?
Confused
You'll have fun fitting a C6 into a Fox car, if that's your plan. C6's are enormous...
Confused
Cool.  I was under the impression GearVendors only had stuff for GM's
Confused
Quote from: Thunder Chicken
Really?  .  It has been done before though right?  What about the C4?
Confused
fits under my floor pan fine:D
Confused
iv heard people fit c4s and c6s into fox cars, but most were c4s. you might be able to get a bullit proof AOD for the price of installing a c4 and modding it tho. even maybe a e4od
Confused
Quote from: SLEEPER T-BIRD 87
 How difficult was it to get in?  Did you do it yourself, or did a shop do it for you?  I'm just looking at options, but really would like to go this route.
Confused
C6 will fit just fine in a fox car, I've had several in Mustangs and Cougars, not really much difference from an aod sizewise.:D
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Confused
Quote from: DakotaEpic
i done it along with the whole 429 swap ..
on the 5.0 all you have to do is cut the spot welds on the crossmember and slide it to were it meets to the mount. you can  even use the stock mount.
Confused
IIRC, there is a small-block C6 and a big-block version. Wasn't there also a big-block C4 available?
For these cars the C4 is lighter, very strong and more managable.
Confused
Hmm well thank you all for the input, it's help immensly and is a good platform to take off from.  I'll do some more research on C6 vs C4, but I might wind up going with the 6 because of the overdrive add-on, as this will be my DD as well for a while.
