Topic: Header won,t fit (Read 2549 times) previous topic - next topic
Header won,t fit
I was installing some shorty headers on my 88 Tbird with a V8.However they are hitting the motor mount on the driver side.I only got the frist bolt from the firewall in.The mount would not allow the others to line up.I am not sure of what the header came off of(Mark or Mustang).So what do I do from here?
 Exhaust-less
Al Green:cool:
Header won,t fit
If itshiznitting the alignment pin, cut it off. If itshiznitting the stud, trim it down to the nut. If it still hits, time to dimple the header. I don't think I've heard of stock headershiznitting the mounts.
Header won,t fit
got pix? i had stock mustang headers on 2 birds and didnt have any problems.
Header won,t fit
Actually, I have an 85 V6 original now a v8, i had issues with the steering column.  had to dimple the headers so to say.
Header won,t fit
i had to heat and bend the tab on the mount for stock mustang headers and the tbird mounts. the tabs are there to hold the motor if the mount breaks. if thats what you mean anyway....it was more the passenger side than the drivers though.
~John~
Header won,t fit
now that i think of it, the cars i put em on were floor shift. if yours is on the column that might be another problem.
Header won,t fit
I have a stock set of Lincoln headers on my car now. They fit with no problems.
Header won,t fit
guess my problem might be the fact i dont use anything stock,  could be why mine hit.
Header won,t fit
I cut the tab that was in the way with a Dremel.
-Jim
1987 Cougar LS 5.0
Header won,t fit
Quote from: al green
 Exhaust-less
at  #5 ?  long tubes and some shortieshiznit the top of the mount just dimple the tube or take a die grinder and trim the mount bracket. and you will be fine.
mine is also an 88
DISREGUARD THE RUUBER CHUNK AND HOSE CLAMP ive got a bad mount:(
Header won,t fit
Alot of times when the header hits the mount is because the rubber part is getting worn out.:D
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Header won,t fit
Quote from: cougarman
mine hit the upper bracket that bolts to the engine block:) it dont move:flip:
Header won,t fit
never had a problem, long or short tubes. :D  :flip: ;)
Header won,t fit
Quote from: SLEEPER T-BIRD 87
If the mount is wearing out the block will drop, causing the parts mounted to the block to drop.
Header won,t fit
:D  maybe it is these genaric flowtechs i have .
AL GREEN : What brand headers are you using?
