Topic: help! out with the h0 in with 351 (Read 2855 times) previous topic - next topic
i cant figure out some egnitiopn problems. How do i wire in a duraspark into my 84 couger! and my fuel is a problem too.
Quote from: billwrks
carb? F.I ?  windsor/cleveland?
All you really need to hook up to voltage, is the red or white wire from the duraspark ignition box(I can't remember, I have slept some since I last hooked one up)...the ignition box needs to be the "blue" unit (the color of the plastic wiring loom where the wires come out)...which came out on almost all of the pre-1980 duraspark II cars...
Does this help?
I hate ysparke just get a used MSD box 3 wires and go LOL
U need power ground and ign so it should not be that hard to do.
Holy cow, its been about 12 years since I have done that swap.Just use the above diagram and you will be fine.Its alot simplier then you think.
