Topic: F.y.i. (Read 1201 times) previous topic - next topic
F.y.i.
just to let everyone know....when you remove your smog pump or theractor pump and pulley...you will need a 94 to 95 inch serpentine belt to replace the original....i just now finished the job...i have a 86 cougar with the v-6 and a/c,p/s. it took several trips to advance auto parts to finally get one that fits. and yes....the car runs great.
F.y.i.
Great tip.
F.y.i.
every time i change my setup it takes on adverage 4 trips with different belts... needless to say the place i go to trys to stay away from me when i come in with a belt:p
F.y.i.
Aww belts ain't a problem, just wrap a string around the pulleys and  mark the spot where it overlaps. Then subtract 1" for the tentioner travel and wa-la there is your belt size....
