Topic: tires,spring???? (Read 2122 times) previous topic - next topic
tires,spring????
hey guy's, fixin to get new tires ,wheels and messin with the suspension the first of the year and i have a couple of ??.
1)- when puting on the mustang front lower arms on , do you need to have CC plates to get a good alignment?
2)- will TC springs lower a 88 sport?? and if so how much?
3)- do ya'll know if it is possible to fit a 285/40/17 - 9" cobra R's on the back?
    255/45/17 - 9" on the front?? if not i'll stick with 275's and 245's .
thanks to all that reply
tires,spring????
c/c plates are a good investment whenever lowering a vehicle.
tires,spring????
I already had c/c plates when i went to mustang lower control arms, so i don't know if they or necessary or not. TC springs should lower about .5" or so. I run 275-40 in the rear and 245-45 in the front. I think i'll try 255-45 in the front next time i need new tires, but i dont know about the 285s in the rear. I'm running 17x9s all the way around.
tires,spring????
on cool cats eric says the TC springs  will lower 1-1.5", bduly, what did you use to lower your car? i like the stance on yours, i am only wanting to go 1-1.5". i am going to run 17x9 all around also, was just wondering if any body has tried the 285's in the back
tires,spring????
I was only guessing on the TC springs, but I hardly got 1.5" with Koni lowering springs. Now I'm running suspension techniques springs, but I am thinking of going with mustang springs in the front to get it a little lower.
