Topic: High Idle/Low Idle Blues [FIXED!] (Read 1733 times) previous topic - next topic
Ok on the 88 TC when I first fire it in the morning it runs and idles fine (minus a few knocks and whatnot, but a tune-up is coming soon). Then after I pull out of my complex to the first light it idles high... around 1800-2100 rpms and stays that way all the way to work. Now that is better than what it used to do, idle low and cut off, until I cleaned out the IAC. BUT! When I fire it afterwards, even if the engine is warm, it wants to die. Put it in gear and drive a bit, it's fine except for the high idle again. What the freak is going on?
I cleaned out the egr.... sorta, the vacuum lines were routed wrong so I disconnected it, because it would sputter and die. Runs great without it.
Also when it's idling high, i can disconnect the IAC and it will go down. Reconnect and it idles around 1000 rpms. Any ideas? I'm so used to thinking about carbs that I can't think of all the components and how they work together. :\
Wish i could help you, I'm a carb guy to.  Computers and cars should never be mixed :nono:
Ok I replaced the car/rotor/plugs/wires and pcv valve all motorcraft. cleaned out the IAC again and now the stoopid thing idles high ALL the time!!!!
Anyone?
Have you pulled the codes, I had a chevy that did close to the same thing was the o2 sensors.
Pull codes for starters
my TC idles at 1000rpms, for a while, it would hang at 1500, then 3000, turned out it was my TPS causing the problems
you know how to pull codes?
no... i don't have a light... though i could try to fab one up. no CEL either. :(
yeah i saw how to pull the codes on nato... sucks starting over. no tools, no garage.
autozone or advanced should be able to pull the codes for you, or is that only on the newer vehicles.
you have a car you can take a tail light socket from? thatll work for the light
cougarman has a scanner. i should be going over his house sunday. we'll see what we get. :)
got two codes... don't remember what the first one was but the second one was TPS out of spec. Voltage was like at 1.6v at idle. Adjusted it to .98. We changed the IAC out, corrected some vacuum line routing and today it idles right at a 1000. Couldn't be happier. Thanks everybody.
codes were 23 and 81. Glad it's running good!!:D
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
