Topic: check this engine (Read 3145 times) previous topic - next topic
check this engine
Will this engine fit into a 88 cat engine bay http://cgi.ebay.com/ebaymotors/ws/eB...tem=8007376164
It should:D  the 03-04 Cobra motor fits in a 93 Fox Mustang http://www.modularfords.com/forums/showthread.php?t=36369
http://www.modularfords.com/forums/showthread.php?t=36406
check this engine
Would look good in a Pinto
check this engine
would work but not worth 5 grand get a kit roushe motor with 450hp for that.
check this engine
yes it will. the seller is actually mustang parts specialists (MPS). it is NOT and easy swap nor is it a drop in. there is alot involved in swapping a modular into a fox...tis the direction my shiznitbox is headed in...god willing.
im pretty much sure roush uses a gt engine (SOHC) wich doesnt realy interest me. that and anything with roush's name on it is overpriced....youd be better of with a modular GT driveline and a blower.
~John~
check this engine
I know roushe is over priced was my point
check this engine
i take that back. i guess they dont even produce a modular engine. i figured they might cause a neighbor has a roush stage 3 car. 5 grand for a complete drivetrain (al be it an automatic) including a 300 hp engine, that sweet shaker setup as well as, wiring, computer, fuel lines, and fuel tank, exhaust, driveshaft, hydroboost with master cylinder and lines, pedals, automatic shifter, speedometer. This setup also includes the front K member with A arms.
sounds like a prett good deal to me. is it a steal, no. is it fair...i think so. if it was just the engine than yeah, the price is high.
when considering a modular compared to a windsor based ford engine your comparing apples to oranges anyway. aftermarket modular stuff is extremely expensive. a SHM longblock is an easy 6 grand. the only way ill be able to afford a serious modular is to buy a used pullout.
~John~
check this engine
It is a fair price, but be prepared for a LOT of work.  The wiring and hydroboost would probably be very time consuming.
