Topic: HEI Hell (Read 4363 times) previous topic - next topic
HEI Hell
*sigh*  Since most of my ignition system could benefit from a replacement anyway I decided to trade up to an aftermarket HEI system I bought on Ebay.  The brand name is Procomp and it's made in Australia but it's pretty much identical to a MSD model.  Trouble is I can't connect it to my Ford harness obviously and I just spent like an hour walking up and down and back up the road between a local speedshop and a basic part store.  I asked for a harness or plug or SOMETHING just to get some electricity to this thing and they all look at me like I have 2 heads.  I know atleast some of you have made this modification so I ask what did you do to adapt it?
HEI Hell
i dont think the parts store will have what youre looking for, unless you go with a GM part, that design is lifted directly from GM, my fathers 81 firebird uses that same setup
HEI Hell
Hmm.  I guess I'll probably go to Pickn'Pull and snip off the right connector for grafting on to my system.  Should work I guess.
HEI Hell
yep!!!
HEI Hell
Quote from: sum_weirdo
be sure and get the left one as well so you can hook up the tach.
My question to you is "why?"  That HEI setup is the ugliest thing ever.  Even Gm was smart enough to put it in the back of the motor.  When you pop the hood people are not going to see a big round air cleaner, they are going to be drawn to that out of place distributer cap.  God its so big and bulky, about 4 inches taller than a duraspark isn't it?
HEI Hell
make sure to get a gear on it to.
im sure you knew just noticed it wasnt there:)
HEI Hell
Yeah I know it's really bulky and could end up being an eyesore in my engine bay but I think the advantages outweigh that.  At some point if I order a black or blue cap from somewhere atleast it will blend in better.  And yeah the bottom gear came separately wrapped for some reason.  I'll have to secure it to the shaft with some glue or something.
HEI Hell
Um, not sure that's how it should go on! IIRC it should either need to be pressed on (like a bearing), or placed on the end of the distributor shaft and held in place with a pin. Or perhaps even both. Someone who's a bit more in the know can chime in and confirm or deny that.
HEI Hell
When I replaced the PIP sensor in my distributor I had to remove it from the motor.  The gear at the bottom was pressed on and also had a pin.  It was a very tight fit and you have to make sure to line up the holes for the pin on the gear and the shaft before you tap the gear back on.
-Jim
1987 Cougar LS 5.0
HEI Hell
There are pin holes on the gear and the shaft but near as I can see they serve no purpose.  For one thing they're at right angles to each other when the gear is on.  And the holes don't intersect or anything.  Also the gear slips on firmly but it slips right off again, I don't know if tapping it will give results.
HEI Hell
Going to have to do something, glue aint gonna cut it pal!
dist
Is this a 302 or 351?  For a 351 the W is different than the Cleveland so sometimes they don't put it on.  Should be held on with a roll pin.  Or maybe it because the roller cam has a different gear and you would use your stock one.
What no directions?
TED
HEI Hell
the roll pin needs to go thru the gear and shaft.
the gear will only go one way and line up with the shaft/roll pin .
if you have any doubts take it to a machine shop and have them install the gear.
HEI Hell
Quote from: Cad-T-Bird 500
What no directions?
TED
pro comps never have directions . i have one in my car also but the msd knock off.
the 351c uses the same dizzy as the 370/ 429 / 460 the will not interchange with the 260/289/302/351w family
HEI Hell
Maybe the machine shop is the way to go.  There's only one hole in the gear and it doesn't intersect the shaft at all.  I can't see any logic in this thing.
