Topic: turbo ler (Read 3170 times) previous topic - next topic
turbo ler
which ones do you think give the best balance of growl/flow for the buck? Cherry Bomb turboII, normal cherry bomb turbo, Thrush, or the summit one?
Re: turbo ler
forgot 1...raptor turbo by flowtech
Re: turbo ler
http://www.dynomax.com/superturbo.stm
This is the ler that I ran on my 88 3.8.
Had a small rumble at idle but made some serios noise when opened up, as opened as a 3.8 gets.
http://www.flowmasterlers.com/40_orig.html
This is the lers that were on my 91 lincoln Mark. Deep rumble at idle and just got louder from there.
http://www.holley.com/products.asp?product=50552FLT
These are what I currently have on my 88 XR7. Very little noise at idle but makes alot when you step on it. This one is my recomended ler.
Re: turbo ler
i like the raptor lers i have had them on several cars and have a deep quite tone .
plus they dibnt neck down inside like the other you mentioned the neck down to 2" pipe inside
Re: turbo ler
Im going with flowmasters. Would it hurt to run Super 40s on a stock 302? They say they are for high horsepower, but all it would do is have less of a flow restriction.
Re: turbo ler
I'd like to go with Dynomax Ultra flow...but it's not in the budget...thinking of going with a set of FORCE fully welded lers from summit racing
Re: turbo ler
i have the turbo II's they sound okay but not the best and they will keep your car quiet and for the price they are kick ass man    im soon changing to flows......
Re: turbo ler
What about some Hooker Maximum Flows? They're straight through, I have a set on my turbo coupe and I really like them. They're $60 each but they're supposed to be all stainless on the inside, I think. I know the Aerochambers are, they're a chambered design vs. the straight through.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Re: turbo ler
I like Mac and FlowMaster.
U could be a bit different and go with Skunk2 Racing ler and sound like half imports out there.
Re: turbo ler
sweet. i want to sound like the imports...
Re: turbo ler
Quote from: Funky Cricket
Got a 3.8 use the dyno max lers. Made mine sound like it ate a set of imports. You know one for each side. :D
But that is only when you ran the thing out to red line. And it wasn't quite about it either.
Re: turbo ler
I want lers that will be loud enough when I rev the engine to drown out any nearby fart cans or thumping stereos.  I have been thinking about putting in basically stock type lers and putting in the bypass valves so I can just open it up totally when I want but have a quite ride the rest of the time.
turbo ler
Electric cutouts can get pricey quick.  And are a little more complicated than just putting in a new ler.  What about Magnaflow?  I just picked up a ler for $60 dollars, but decided to wait to put it on till after I swap in a new 5.0.  They are all stainless steel, all the welds are garunteed for life, and they are wide open pass-through up to 3 inches.  I got a 2.5 inch.
Paul
turbo ler
Quote from: DakotaEpic
Warlock+ Electric cutous = Open exhaust
turbo ler
The flowtech warlock ler showed in the previous post will make more power and torque than any other ler hands down(when opened, when closed it sucks).  Or you could be a cheap  like me and buy a pair of 2.5" dynomax super turbo lers with the offset/offset configuration and turn it into an ultra flow with the quick use of a 2.5" hole saw. :hick:
