Topic: Installing a torque converter.. (Read 1887 times) previous topic - next topic
I'm going to be installing my newly bought torque converter before I put the engine back in my car.  Without the engine, the torque converter is ofcourse exposed to the engine bay and that's where I plan on doing the swap.  Only thing is that the instructions are intended for a transmission that has been removed from the car and unfortunately I can't easily drain the transmission from the pan because that's where the jacks contact the transmission to support it.  I guess my question is: can I just remove the torque converter and let the fluid drain from there instead?
Re: Installing a torque converter..
You will loose very little oil when you remove the converter.  Make sure when you install the new one all the way in, this may require rotating it a few time, I think it may drop three times.
Also with a new converter you need to put a quart of oil in it before you put in on the transmission.
Good luck and have fun.
TED
Thanks  ;)
Haynes manual, bottom corner of page 111:
make sure that you hear "3 clicks" when installing the torque converter. this will let you know that its all the way in.
Right.  The three clicks are very important. I dozed off bolting my engine and tranny together once and bent the hell out off the flex plate. I thknk I only went one click. It was about a half inch too far out.
