5.0 intake studs? September 30, 2005, 03:01:56 PM does anybody use them? seems to me that they would make putting the lower intake on easier without moving the gaskets....my lower has a leak at the back seal, and I am trying to fix it once....Rick Quote Selected
Re: 5.0 intake studs? Reply #1 – September 30, 2005, 03:45:42 PM Actually,that sounds like a great idea.I have never thought of that.Good thinking ol' boy. Quote Selected
Re: 5.0 intake studs? Reply #2 – September 30, 2005, 03:48:16 PM Quote from: vinnietbirdActually,that sounds like a great idea.I have never thought of that.Good thinking ol' boy. THANKS :D Quote Selected
Re: 5.0 intake studs? Reply #3 – September 30, 2005, 07:56:30 PM i was thinking about using just 4 of them, one at each corner Quote Selected
Re: 5.0 intake studs? Reply #4 – October 03, 2005, 12:09:46 PM I use assembly studs on everything I can that uses a gasket or sealer. They especially work great on valve covers and waterpumps also. I have no engine leaks at all which I attribute to the use of studs during assembly. I just make mine using longer bolts that I cut the heads off of. Just make sure they're very loosely threaded in so you can get 'em back out after you start your bolts. Quote Selected
Re: 5.0 intake studs? Reply #5 – October 03, 2005, 05:09:45 PM I have 4 ARP carb studs at the corners on my intake just for the fact that its easyer to line up the gaskets and intake. But using all studs can be a bit of a prob if u take your intake on and off. Quote Selected
