Topic: Want new tires, what size to get? (Read 2956 times) previous topic - next topic
Its time to buy some new tires. I was wandering what size you all like and think I should go with.  I have snowflakes on my car now.
Re: Want new tires, what size to get?
I'm using 245/50/16's, and they fit fine. I'd advise, since you don't have quad shocks, that you get 255/45/16's on the rear and 235/50-55/16's on the front, as the 245's tend to wander every time you find a rut in the road.
Quote from: oldraven
And if lowered you will have rubbing issues when turning sharp corners.
Quote from: slamedcat
If he went with 245's, you mean? I know at stock height mine have never come close. Would the 235's?
Yup the 245's are a little to big if you lowered the car. I know I have that problem now. I also hit the fender lip if I hit a bump too hard.
Not sure on the 235's. I have also run 205/55R16 real small close to the ground watch for small animals.
225/50R16 are a little better.
my 225's wander too
Slamedcat...your signature has me rolling dude, i cant breath, oh got thats funny
I've got 245-45-17s on the front of my lowered bird. No tire rubbing issues. I had crazy wondering with spoogeho tires, where the tire would catch every groove in the road, but I got new tires (Riken) and they have zero wondering effect. That's just what I'm running. Goodluck.
you have the mustang control arms though
True, I forgot....but I was running 235-45-17 before the mustang control arms without rubbing. Thanks for the reminder.
oh man that sig is just tooooo funny.
Tire rack doesn't have 255/45 r16s but i like the idea of 245 50s
What about the Sumitomo HTR Z.  There cheap and thats what I want for the $300 cat!
Looks like a nice tire. :) But if you would like to try the bigger rears, why not just go somewhere else? I got my Toyo's through a local dealer for $800 ($680US).
kinda pointless to go that much bigger imho. I would just get wider tires of the same size. At least with the wider tires there wil be more traction. Maybe slightly bigger in back and smaller up front.
As bad as it sounds you may try your local walmart or sam's club.
They have a huge selection of special order tires. That where I got my G Force T/A tires from. They were right around $107 a tire. That was about 2 years ago so the price may have changed.
On a 7" wide wheel...no wider than 245...
You will get wander and float on anything less than a V-rated tire...the sidewalls are just too soft, and it will be worse if you go too wide.
I'm a big fan of the Sumitomo tires (going to get a set for the Z-7 here soon, but if you live in a place that gets any snow, and you plan on driving that car in the snow....look at another one of the Sumitomo HTR all-season performance tires, such as the HTR+.
