Topic: crankcase vent/oil pan questions (Read 931 times) previous topic - next topic
I have an 88 5.0.I need to know is the crankcase vent element removeable?I have a chilton shop manual and it shows in the fuel system section,it looks like the element comes out.Do I need tool to remove?I do believe its clog up.When I remove the pcv grommet & the pcv valve they both had buildup.Can I replace it and how.
 My oil pan has a leak in it thats been repaired before.
I want to replace it but the pan that I have does not have the sensor on it.Does it bolt on to the pan(the sensor) or will I need to get another pan.The motor is out of the car.
 Thanks
Al Green:cool:
