Re: Fox Fuel Efficiency, part 2 (long post again)
Reply #4 –
That definitely sounds like the way to go, make it light as hell, build a 2.3L turbo motor and you should be set. However, TC's weigh more like 3200lbs so you could still get better mileage if you stipped a Fairmont/Zephyr down to under 3000lbs. I disagree on the point about leaving the 7.5" rear in it. If swapping to a 2.3L TC set-up, why leave the spindly little 7.5" rear in it when Ford decided it would be prudent to put the 8.8" in the TC's. Those 7.5's are rather wimpy...mine was on the brink of falling apart with only 100k on the clock and 96k of it was behind an SO engine that never saw abrupt throttle inputs or revved past 3500.
Stock 8.8 from an AOD stang ought to do the trick, posi and 2.73's should be perfect for what could be a fairly light car.
