Topic: Finally getting around to it... (Read 5891 times) previous topic - next topic
I was going to keep it all under wraps untill it was done, or almost done, but im bored, so im posting it here
no, its not assembled, i just set the heads and intakes on it, and for the hell of it, i stuck the headers on it
the plans for it right now are basically fully tear down the short block, clean everything the best i possibly can with what i have, reassemble it, stuff an HO cam in it, HO upper and throttle body, and gather all the other stuff i need for the swap, which will all come in time
still need a water pump (not gonna be a factory one, youll see later on), oil pump, oil pickup, head bolts, intake bolts, mounts, and all kinds of that small stuff that i dont have just yet
theres a lot im doing that im not going to post, not yet anyways, its not for going fast, but its just a setup i want to run, maybe next time i get bored, ill post it up
i also need to take some other pics, i have a distributor sitting in it, and valve covers sitting on it
Re: Finally getting around to it...
The power to weight ratio with the engine on that stand is gonna just be awesome... :D
Well take your time and dont rush things.
Quote from: TurboCoupe50
the problem is trying to hook up on those steel wheels, and trying to make it down the track on the casters up front
shawn what brand headers are those?
are they the flowtech 12104's ie 387-12104's from jegs?
that look's like a engin stand from advance auto
You do have an H.O. computer don't you?
Quote from: Blown306Cougar
They sure are, as long as they fit, i dont care, they can leak a bit, its no big deal, theyre only going on the car because i have them laying around
Quote from: BEARMAX
It sure is
Quote from: vinnietbird
Sure do, and a harness, and a superchips module
Quote from: Tbird232ci
*yoda*flowtech's they are you have..
*yoda* have fun installing them you will!!
*yoda* the force is strong with them they are!!!
i own them... enjoy installing them.. i did'nt :shoothead
you won't be able to use the stock 3180/3186 starter. you will have to use the late model starter 3205 or after market mini starter
but they will fit!!! but not fun!!
more
I kinda saw this coming
The fitment isnt too much of a big deal, my engine bay will mostly be empty, and since i havnt aquired a started yet, ill be on the lookout for one that will work
what made them oh-so-fun to get in, i see on the drivers side, one of the primarys kicks out pretty far
well since they are equal length long tubes.. all tubes fit tight everywhere..
oh and you asked about the one tube that sticks out real far on the drivers side well  :giggle: that goes around the steering shaft..
since i have had mine "about 3years" i don't know if they changed anything about them..
Shawn how meny slip s does your headers have? "removable headertubes" i think just about all of mine are except three of them i think..
the one that goes around the steering shaft should be removable
Nick
i havnt looked, and i dont quite feel like looking right now, but ill grab a picture or two and post them
question on the starter, Eric mentions a later model starter thats smaller, and a little write up on coolcats
http://www.coolcats.net/tech/advanced/starter.html
that one there, thats the one id want?
yep like i said in an earlyer post the part number is 3205 thats the basic aftermarket part number..
