Topic: How to check timing on early model 302? (Read 1010 times) previous topic - next topic
My brother has a '84 F-150 with a 302 in it and it idles like  most of the time. I wanted to check the timing because I don't think it's been set or checked in the time he's owned it. However, looking at the engine I can't see how you do it. I don't see any timing pointer anywhere, or timing marks on anything. I thought they were on the damper? Although, it's down under the water pump and everything and you can barely even see it. Also which bank has the #1 cylinder on it?
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Re: How to check timing on early model 302?
# 1 is the firont one on Passenger side
the pointer will be on the passenger side lower front cover  the dampner is marked also get you a scotch brite and scuff it off as they get cruddy
