Topic: Coil Springs (Read 2103 times) previous topic - next topic
Coil Springs
Is the coil springs between TB Turbo Coupe and Mustang the same? The reason I ask is because I want to lower my 88 TBird but they dont make it anymore and I was thinking that using Mustang lowering spring should work. Will it work and what specifc or year do I need? Thanks!
Re: Coil Springs
You can use the search function to find out more, and there is a thread full of info on what springs, and pictures afterwards...
But, If you can get your hands on a set of Eibachs (like I did  :D ), they work, but arn't made anymore as you mentioned... so, fox Mustang springs work in the front, and you can use SN95 convertable springs in the rear to lower it a little. As in many other ways to go... here: http://foxtbirdcougarforums.com/showthread.php?t=62&highlight=springs+pictures
Frank M
1985.5 SVO
Re: Coil Springs
No they are not the same. Follow that link turbo83coupe posted, it contains lots of pics. Including ones of mine with Mustang Bullitt springs.
Re: Coil Springs
eh..something worth mentioning is that most of the time when somebody mentions mustang springs they mean STOCK mustang springs and NOT springs meant to lower a mustang. springs meant to lower a mustang will generally set the car way to low if not on the fender...
~John~
Re: Coil Springs
OK, but wont Mustang springs give you funkey handling, becuase of the different weight proportions of the two different bodies??
Matt :tg:
Matt :tg:
