Topic: Rebuilt Cougar 5.0 engine (Read 887 times) previous topic - next topic
I have a complete 5.0 from an 88 Cougar.  It has all new seals and gaskets.  I have lapped the valves and replaced the valve seals.  It has an Explorer HO cam and new oil pump, double roller timing chain and water pump.  Has 19LB injectors or I can supply the stock injectors to use with a stock computer.  It has a non-TFI distributor in it so you may need to get a standard distributor for it.  Runs great.  The engine is located in the Cincinnati Ohio area.  I will sell it for $350 complete  or will separate.  Email bob@cinti-biz.com
Re: Rebuilt Cougar 5.0 engine
I also have a set of stock fox mustang headers for $50.
