Topic: gauges dont work (Read 1972 times) previous topic - next topic
gauges dont work
after gettin my enigne intsalled. i noticed that my oil and temp gauge dont work. the other two are fine. what is it and where is it that he forgot to hook up when my mechanic replaced the motor?
88 sport 308 e-303, ported e7's, cobra intake, cold air, under drive pulleys, full exhaust, t5, 373's, smog pump removed, 255 pump, pressure regulator.
                        :birdsmily:
Re: gauges dont work
sounds like the sending units were left unplugged.  oil is down by the oil filter and the temp should be up on the intake I could be wrong but thats where it is on my SO
Yes, the temp sending unit should be at the front driver's side of the intake manifold.
