Topic: k-frame (Read 1570 times) previous topic - next topic
k-frame
ok I want to use mustang motor mounts but don't want to swap the whole k-frame,  is it possible to cut the metal pieces off the mustang k-frame and weld to the t-bird k-frame?
1988 ThunderBird Sport
5.0 HO, 11" Mustang brakes, Pony rims
 :america:
Re: k-frame
Sounds like a big PITA to me, but it might be possible.
If you're interested, I'm working on some poly motor mounts for the 86-88 5.0s.  They're still in the prototype stage at this point, but they will be available in the not too distant future.
Re: k-frame
My 85 i have stang mounts i dont know if there is a difrence in 86 or not.
I know in the 87 TC there some strange  there but i'm going tube K in that car over the winter.
Re: k-frame
Quote from: SirChirpAlot
All '86-'88 Birds/Cougs use the same unique K member... '85 earlier use the Mustang mounts.
Re: k-frame
Quote from: TurboCoupe50
I had no clue.... i was so confused about this issue. :crazy:
k-frame
Chuck W....I would be interested in purchasing some of your poly motor mounts for the '86-'88 5.0L Birds also.
1988 Thunderbird
306 HO w/ A9P processor
AOD w/ Transgo Reprogrammer
245/50/16 Tires on Snowflakes
k-frame
it would be easier to just swap the k-member or pick up a tubular one cheap.
