Topic: Got new tires....took some pics... (Read 3180 times) previous topic - next topic
I put 245-45s on the front and 275-40s in the rear. I have ZERO issues on the front with this size tire...infact I may go a step wider next time around. Before I had 225-35s and they were too small for 9" wide rims.
Re: Got new tires....took some pics...
looks good
One more.
I didn't even notice it with the tires alone. But I put in a 3.73 TC rear end this summer and have yet to change the speedo gear. The speedo is basicaly useless right now.
What is the backspacing on your rims? When I changed over to 5 lug with 03 cobra rims w/245 45 my front tires stick out just slightly. drives me crazy.
[SIGPIC][/SIGPIC]http://www.fquick.com/slicksport88
88 Sport - 5.0HO, Mass Air, A9L, 73mm C&L meter, BBK CAI, 255 lph pump, 1.7 roller rockers,Professional Products damper, Chuck W motor mounts, BBK shorties & H-pipe, Flowmaster 40 series, 8.8 rear w/3.27's, 93 Cobra M/C, BAER 13in. drilled/slotted rotors front and back, cobra calipers, Russell braided brake lines front & back, C/C plates, 03cobra rims, 255/40/17 Nitto 555's all around
i believe he put mustang front control arms on his car
Quote from: Tbird232ci
Exactly. Fox mustang lower control arms are the instant cure for that issue.
I Like It, As A Matter Of Fact My Car Is Almost The Same As Yours But My Tbird Is Running 235/45/17 Front On 17x8's And
275/40/17 On The Rear 17x9's. And The Car Is Lowered Fms C Springs On Front And  The 88 Sport Springs On The Rear With One Coil Cut. I Put The C Rears On But It Sat Way To Low. Any Way Your Car Is Very Nice. :d
                        :birdsmily:
Quote from: bduly
What are your alignment specs with the Fox arms? How much negative camber can you get?
looks good
Car looks great.
Very nice and clean pictures too by the way. :D
nice.. like the stance with those big tires on it.
Wow, 245´s in the front without problems, thats a good job. I like it.
These 205 60 in my car are KILLING MY CORNERS ! (Hey, do you wanted to be different using Contour Rims Right ?.....)
1985 Mercury Cougar V6
1989 F-200 V8
1996 Explorer V6
2001 F-150
