Topic: another radio question (Read 2086 times) previous topic - next topic
do the stock brackets on the stock radio bolt onto most aftermarket radios? so it would be a bolt-in?
i jumped the gun and bought an install kit, but then i noticed these brackets on the sides of the stock radio. :rolleyes:
87/88 t-bird BTW
1979 Ford Fairmont
[/B]
Re: another radio question
I would use the install kit. The brackets are most likely to be rivited in place on the stock radio.
I was able to swap out mine.  In fact, the side of the radio and the brackets have several different positioned holes and locations for mounting that you can manipulate the mounting bracket to effectively shift the radio further back or forward.  Check it out by toying with the mounts to suit your situation.  I remember thinking with the Pioneer install--wow glad I noted it.
Quote from: slamedcat
but they're not. they have two small screws on each side, that attaches them to the radio.
i know on my wife's corrola(RIP), i used the stock brackets on her pioneer head unit.
1979 Ford Fairmont
[/B]
On my Pioneer, I put the right bracket on the left, and the left bracket on the right, slightly filed the holes in the plastic dash for the pins to clear, and screwed it in.
All of mine where rivited inplace.
